Cluster Filter
VK7CW
Cluster Filter
Post by VK7CW »
When I have the cluster filter set to CW (which is all the time) on certain bands I am still receiving digital spots.
For instance on 30m if I have the filter set to CW I am still getting spots for FT-8 station on frequencies on and above at 10136.
I do not wish to receive these spots and I thought that is what the filter was for.
It is a similar story on 40m however it is opposite where CW spots are not shown around 7030 to 7050 ( I dont know the exact edges).
My question is how do I adjust the frequency edges for the CW filter?
Is it a setting in LOG4OM or is it a setting in the DX Cluster connection?
Is it user adjustable or is it in the software?
It does get very annoying and I wonder if anyone else experiences this problem?
It is mainly limited to 30m and 40m bands.
I am sorry if this has been covered before but I did do a search on this forum and in the User Guide and could not find anything at all.
Any help/suggestions appreciated.
73 de Steve VK7CW
K7PT
Re: Cluster Filter
Post by K7PT »
The Log4OM mode filters are set per the region band plan, R1, R2 and R3. I believe you are are in region 3. Do you have the correct region selected in the Log4OM settings?
Re: Cluster Filter
You can modify the bandplan to suite your particular requirements or better still send a filter to the cluster that you prefer so that you only receive CW spots.
See http://wiki.dxcluster.org/index.php/DXS ... ing_Manual for information about setting cluster filters.
Commands are sent using the Log4OM cluster command facility
VK7CW
Re: Cluster Filter
Post by VK7CW »
Yes I have the correct Region in LOG4OM settings.
Terry is this user selectable within LOG4OM? If so how is it done as this would be my preferred option?
VK7CW
Re: Cluster Filter
Post by VK7CW »
Disregard my last I finally found the "bandplan_r3.xml" file.
I have edited it and modified 30m and 40m freq/modes to suit my own personal needs.
All tested and works great now, I ended up answering my own question.
For anyone interested you need to find your region bandplan files be it r1, r2 or r3 "bandplan_r?.xml"
In my case it is located under C:/users/owner/AppData/Roaming/LogOM/bandplan_r3.xml
Right click on the file and select edit. This will let you edit the bandplan in notebook.
I made sure I saved the original unedited file in case I made an error.
Once edited to your preferred settings, save it. I then closed and restarted LOG4OM and it worked a treat
Thanks again,
73 de Steve VK7CW
