only performed in late morning country, lotw user etc. update and closed.
in the afternoon program start then stop itself with details:
Firma problema:
Nome evento problema: CLR20r3
Firma problema 01: logomui.exe
Firma problema 02: 1.31.1.0
Firma problema 03: 5a6ed0ee
Firma problema 04: System
Firma problema 05: 4.0.0.0
Firma problema 06: 4ba1dff4
Firma problema 07: 1cf6
Firma problema 08: 8f
Firma problema 09: System.AggregateException
Versione SO: 6.1.7600.2.0.0.256.48
ID impostazioni locali: 1040
Informazioni aggiuntive 1: 4be7
Ulteriori informazioni 2: 4be78fdd727e4350d8f2189583321f8d
Ulteriori informazioni 3: 00c1
Ulteriori informazioni 4: 00c123220e57133116efa033fa755380
Leggere l'informativa sulla privacy online:
http://go.microsoft.com/fwlink/?linkid= ... cid=0x0410
Se l'informativa sulla privacy online non è disponibile, leggere quella offline:
C:\Windows\system32\it-IT\erofflps.txt
then tried to reinstall actual version but not improving: program always start then after few second (not always same time) stop itself asking to find a solution online or close software.
many thanks for attention.
best 73 Paolo, IZ1ESM
Log4OM stop to running
Re: Log4OM stop to running
Hello Paolo,
don´t have any Idea about those error mesages in italian language but
have informed Lele by eMail.
Hello Juergen,
thanks and sorry ... Log4OM is intalled in English but O.S. in Italian ..
just to add (quick translation):
problem sign:
problem event name: CLR20r3
problem sign 01: logomui.exe
problem sign 02: 1.31.1.0
problem sign 03: 5a6ed0ee
problem sign 04: System
problem sign 05: 4.0.0.0
problem sign 06: 4ba1dff4
problem sign 07: 1cf6
problem sign 08: 8f
problem sign 09: System.AggregateException
Version OS: 6.1.7600.2.0.0.256.48
ID local setting: 1040
added Information 1: 4be7
other informations 2: 4be78fdd727e4350d8f2189583321f8d
other informations 3: 00c1
other informations 4: 00c123220e57133116efa033fa755380
best 73, Paolo
problem sign:
problem sign 08: 8f
best 73, Paolo
Please submit a support request (help/bug report) and include the ADIF file
See here for how to do this http://www.log4om.com/log4om-support/
SEND BY EMAIL DO NOT POST IT ON THE FORUM
yes, I saw that it had to be done like that, so I' ve already tried yesterday but program always stuck before ending operation ....
anyway I will try again ..
thanks
thanks
today I've test to run Log4OM with always same result ...
in one attemp, before program stop, I've gained the "setting/option" menu then found any selectable configuration was present and only new configuration was available then I create a new one, opening my old Database and all was running again (with all setting as dafault).
after I've tried to update on "setting" menu, the IOTA, Sota, Country and all database pointing the default selection (i.e. external web site, RSGB web site etc) and again program fails and close. One time more opening program, due the last action performed before stuck, I've open help/about finding the date situations as attached.
anyway, this time I've created the trace for bug report and I will send it as requested.
best 73 Paolo
best 73 Paolo
- Cattura.JPG (46.57 KiB) Viewed 4013 times
Re: Log4OM stop to running FIXED
Used Log4OM for many time with pending problem, running only without performing any database update through setting menu. Then found the blocking cause with Clublog and IOTA database update.
Also full unistall and reinstall of 1.31 or older version had notsolved while the latest version required a system update and the time availability to perform it. Finally installed the atual v1.32.0.0 and all seems working as expected: the date showed on each database is current.
Thanks Terry for help. best 73, Paolo
