I had to replace a hard drive recently and it caused me to have to re-install Log4OM. I have all of my QSOs replaced with ones from LotW. Before the crash, I was uploading QSOs without any problem. Now I get an error when I try to upload: Error: The selected station location could not be found. The box I have filled in on the "Log4OM Upload LotW" page under station location is "HOME".
I notice that the Log4OM program doesn't have a presence on %appdata% roaming with my new installation. It seems Log4Om didn't create it this time when I installed it.
Does anyone have any ideas?
Steve, W6SDM
Can't Upload to LotW
Re: Can't Upload to LotW
You wouldn't get the program to run if it had not created the LogOM folder and its contents
Did you install the TQSL software?
Yes, I did install TQSL. I realized when I just checked it that I hadn't installed a certificate on the new computer. I did complete that task but I am having the same problem, getting the same error.
Steve, W6SDM
Steve, W6SDM
Hi Steve,
did you have restored the Log4OM configs from your latest Backup ?
If yes it youd be possible that your TQSL Path is different. Have you
set the new path in Log4OM to the new installation of TQSL ?
Meanwhile i´ve changed my machine 3 times and always my uploads
to the different services working fine ... Could be only an error on the
"user" side ...
"user" side ...
It's working now. The problem was that when I re-installed TQSL and the certificate, I didn't specify a location. Once I did that, everything worked.
Thanks for your help!
Steve, W6SDM
Steve, W6SDM
