How to recover setup data?
Posted: 24 Mar 2018, 14:15
After installing .32 version, I have a problem where Log4OM opens and has no setup information and asks me to fill that all out again. (Initially it opened properly - this was a subsequent program start.) This happened on an earlier release as well, but now I'm concerned I'm going to miss something in my re-filling all the setup options. Is there a way to recover the setup from earlier? I've tried copying the config.xml that is saved in the backup ZIP file into the Log4OM program root directory, but that doesn't seem to make any difference.
The cause of this is not likely to be a Log4OM problem as I have also lost a couple USB devices (driver issues?) at the same time following a Win10 update. So, at this point I don't know if the 2 year old HD is going on me, MS has hosed something again, or there are other problems. Thankfully, besides the Log4OM backup, I do regular data backups as well....
