radio has delayed response to cluster click freq change
W2GTR
Post by W2GTR »
When I double click a call sign in the right side cluster display, the radio will change to the new frequency, but it takes anywhere from a second or two to 10 or 15 seconds sometimes.
I use Omnirig to interface with my Kenwood TS-140S. I use the same settings as Omnirig uses when using N1MM+ and in that program the radio responds instantly to a single click every time. Not trying to compare the programs, just illustrating that my radio can respond quickly using the same settings. I have omnrig set to the lowest possible polling rate of 100ms. That helps but there's always at least a second or two of delay.
Is there any way I an improve the response time.
thanks,
Ed
