Can I reject by frequency on the cluster?
WR3Y
Post by WR3Y »
Is there a way to reject all Ft8 spots by using "reject by frequency command?" I don't want to see any.
TU
WR3Y
Re: Can I reject by frequency on the cluster?
If you are using ve7cc cluster viewing the ft8 signals can be toggled off. I think it defaults to off from the git-go.
DXSpider commands from the Log4OM cluster send command will do a reject mode see http://wiki.dxcluster.org/index.php/DXS ... ing_Manual
