Is it possible, from within Log4OM, to select which certificate or station location to use when submitting calls to LotW? From what I can see from the LotW site, I will have to manually sign an exported ADIF log.
I am thinking of when I will be operation as GR4DWV later this month for the Wedding.
73 de Guy G4DWV 4X1LT
LotW and two locations
Re: LotW and two locations
Use a separate configuration for the other call using the appropriate certificate data
Okay. So all I have to do is copy the config and change my callsign? All details should remain the same for the new LotW certificate as I did not get a separate password.
Cheers
Guy
Cheers
Guy
