Version 2.1 will not work the Swiss developer wont fix its bugs, you must use Version 1.19 from Alex at afreet here http://dxatlas.com/OmniRig/Files/OmniRig.zip
You can edit the ini file search the forum and google for what to do
Icom 7300 ,LOG4OM ,omnirig and WSJTX (FT 8 filter size)
Re: Icom 7300 ,LOG4OM ,omnirig and WSJTX (FT 8 filter size)
To save you time searching on the web, here my helping hand.
To solve the wrong filter setting when using OmniRig , the IC-7300-DATA.ini must be nodified.
Read this article:
https://www.cademuir.eu/blog/2020/09/16 ... 2-problem/
The IC-7300-DATA.ini can be found in folder Program Files (x86)\Afreet\OmniRig\Rigs
Use the program Notepad++ to edit the ini file and save it back to the Rigs folder of OmniRig.
Best 73, Fred
Read this article:
Best 73, Fred
