Callsign Lookup not working right
KD0Q
Post by KD0Q »
Hello All!
Having a problem with callsign lookup.
KH1/KH7<any character> returns the country as Hawaii but KH1/<anything other callsign> returns Baker Island.
For example:
KH1/KH7Z fills in correct name, but country is Hawaii.
KH1/KD0Q fills in correct name, country is Baker Island.
Any ideas?
Thanks, Glenn KD0Q
Re: Callsign Lookup not working right
Hi Glen,
don´t know what´s wrong at your side but here is working fine (see screenshot).
B.t.w. which version of Log4OM are you using and all the data files up2date ?
(Country- and SCL-Database under the settings TAB)
KD0Q
Post by KD0Q »
I'm using version 1.32.0.0. Just updated all databasse and restarted Log4OM. Same result.
Try your test with KH1/KH7Z instead of KH1/KH7ZZ.
K7PT
Post by K7PT »
Closely examining the country file, I found the issue and have corrected it the country file dated Jun 28, 2018. User need to download this update.
KD0Q
Post by KD0Q »
Thanks for jumping on that Chuck but it still doesn't work for me.
Is it something about having KH1/ instead of /KH1?
K7PT
Post by K7PT »
I'm looking at a few things on this now. Get back soon. I hope!!
Have checked that here too. If i use KH1/KH7ZZ i will get the correct DXCC Baker but if i use
KH1/KH7Z i have also Hawaii here ....
K7PT
Post by K7PT »
Daniele is looking into it and hope soon he will have a fix. So, stand by guys.
Update your Clublog database and both calls look up correctly
have tried this but always Hawaii ....
Version is the latest for the test team ... ;)
