how to communicate Log4OM with MSHV
sp8sn
Re: how to communicate Log4OM with MSHV
Post by sp8sn » 13 Aug 2018, 15:13
IW3HMH wrote:
09 Aug 2018, 14:44
You can broadcast whatever you want... if nobody listen it's hard to have an answer :D
Hallo. Do you suggest that Log4OM does not listen?
This the the best logging program I've used, but MSHV is the best for some digi modes.
I would like to "marry them".
Robert SP8SN
73, Robert SP8SN
F1ABL
Post by F1ABL » 13 Aug 2018, 15:40
I have the same opinion as Robert, I would like to be invited to the wedding hi!
F1ABL Michel JN24of
Post by IW3HMH » 02 Sep 2018, 10:23
I'll check what this software is broadcasting...
Any link to the application webpage?
sp8sn
Post by sp8sn » 02 Sep 2018, 11:23
73, Robert SP8SN
sp8sn
Post by sp8sn » 23 Sep 2018, 09:41
IW3HMH wrote:
02 Sep 2018, 10:23
Hallo Daniele.
Did you try to solve the problem. Do you have any way to log in QSO from MSHV to Log4OM?
Robert
73, Robert SP8SN
Post by G4POP » 23 Sep 2018, 11:09
What is so much better or different in MSHV?
sp8sn
Post by sp8sn » 23 Sep 2018, 14:25
All modes in one aplication, I have no FSK441 in wsjt-x
73, Robert SP8SN
Post by G4POP » 23 Sep 2018, 14:34
Thanks Robert, I had a look at it but missed that advantage
sp8sn
Post by sp8sn » 23 Sep 2018, 14:40
It is not that important, but it would be good to launch such functionality. I often take part in NAC contest (at least twice a month on 4m and 6m bands), we usually use FSK or JT6, it would be useful to be able to log in automatically.
Regards Robert
73, Robert SP8SN
Post by IW3HMH » 10 Oct 2018, 16:34
I've checked the software, it's hard for us to enable Log4OM intercepting software calls, as they are a lot, and loggers are pretty few.
Usually the software will connect to the log, and not the opposite, except for some "masterpieces" widely used.
Adding a catch broadcast in Log4OM for a good-but-niche (to the date) software is not in our immediate priorities.
