SOTA REF- 7A/BO-066
TERRYG0VWP
SOTA REF- 7A/BO-066
Post by TERRYG0VWP » 22 Jul 2018, 05:01
Trying to put SOTA Ref in for Bosnia-Herzegovina 7A/BO-066, but Association/Region all blank cannot input this ref, can you help.
Best Regards
Terry
Re: SOTA REF- 7A/BO-066
Post by G4POP » 22 Jul 2018, 06:32
There was a syntax error in the SotaAssociations file
Please unzip the attached file and save it to your C:\Users\YOUR USER NAME\AppData\Roaming\LogOM folder and then restart Log4OM
SotaAssociations.zip
(1.27 KiB) Downloaded 32 times
Post by G4POP » 23 Jul 2018, 07:30
In the process of locating this users issue I have discovered that SOTA MT have again made changes to their summitlist which will cause issues with ALL external logging software. They dont consider that a small change as below stops other software reading the file.
Canada - (Alberta) changed to Canada - Alberta
I have spent several hours checking the incoming summitlist file and edited our SOTAAssociations file accordingly. I may not have found every change made by SOTA MT so would ask you all to notify me of any issues.
Please download the updated file by going to the Log4OM settings/SOTA Database/Download updates.
All of this work could be avoided if SOTA MT just added the DXCC reference to their Summitlist entries.
