Missing country on some qso v1.32.
Re: Missing country on some qso v1.32.
F1NQP wrote: 24 Jul 2018, 15:46 it's good it worked.
All the countries are now informed, and I had duplicates.
Thanks for the tip Terry.
73 and good traffic.
F1NQP Jean-Jacques
Just proves once again it always helps to read our user manual and watch one of the dozens of YouTube tutorials we have provided :roll:
F1NQP
Post by F1NQP »
Unless I am mistaken, I consulted the notice in FR and I did not find this.
Thanks for the video tutorials, I did not know.
Thanks again Terry and have a nice day .73
HB9BRJ
Re: Missing country on some qso v1.33.1.0
Post by HB9BRJ »
Sample log entry sent by GridTracker to Log4OM (taken from the Communicator log):
2018-07-29 12:35:51.0318 DEBUG: TCPManagement: Incoming QSO from TCP Connection (ADD) <BAND:3>12m <CALL:6>SP6ECQ <FREQ:9>24.915831 <MODE:3>FT8 <QSO_DATE:8>20180729 <TIME_ON:6>123100 <QSO_DATE_OFF:8>20180729 <TIME_OFF:6>123545 <RST_RCVD:3>-03 <RST_SENT:3>+07 <TX_PWR:2>20 <GRIDSQUARE:4>JO71 <STATION_CALLSIGN:6>HB9BRJ <MY_GRIDSQUARE:6>JN47hq <EOR>
This shows that the country is indeed added by Log4OM. In 2 out of 8 QSOs made yesterday, there was no country and I had to enter them manually by editing the QSOs in Log4OM.
73, Markus HB9BRJ
F1NQP
Post by F1NQP »
Hello Markus.
I still have the same problem too, and from time to time, a country is ignored and remains blank in LOG4OM without me really knowing why.
I go through the qso manager to put the missing country back, but it's a curious problem.
If you find a solution, please keep me informed.
73 qro and good traffic.
I'll check that.
If DXCC is calculated by Log4OM itself, it's strange the country it's skipped.
[EDIT] Data provided by external sources are leaved UNTOUCHED and skips all checks by Log4OM procedure.
I'm adding an "enrichment and external source check" parameter to settings to enable Log4OM to make more checks on imported data
I'll check that.
I'm adding an "enrichment and external source check" parameter to settings to enable Log4OM to make more checks on imported data in the SERVICES screen
F1NQP
Post by F1NQP »
Hello Danielle.
Yes I still have the problem. From time to time I pass the incomplete qso to the grinder with the utility, and that solves the problem.
But it's tedious. Waiting for a fix I'm doing that.
Thank you again for your work and good luck.
73 qro
