Page 1 of 2
IC7610 Support on HamLib
Posted: 31 Jul 2018, 07:45
by m0vue
I've given up with OmniRig I just cannot get it working with my 7610. However, HamLib is working with WSJTX and other apps, but the 7610 is not in the list of rigs within Log4OM. I'm assuming I just need to update the Rig library and I should be ok? If so where is the library located on a windows 10 install.
Chris
M0VUE
Re: IC7610 Support on HamLib
Posted: 31 Jul 2018, 09:09
by DF5WW
Try C:/user/username/appdata/roaming/logom/hamlib ...
But why you don´t get Omnirig to run ? Did you run it as Administrator (recommended) ?
Most of all users have problems with hamlib but not with Omnirig.
Posted: 31 Jul 2018, 13:20
by m0vue
I have tried a lot to get Omnirig running and I can't. I've tried two different PC's and radio.
I've been using the Omnirig client to debug and this is what I get, no matter what settings.
- Omni.PNG (47.26 KiB) Viewed 6111 times
The thing is other applications are working fine.
Chris
Posted: 31 Jul 2018, 18:44
I wonder if you failed to install the genuine Icom USB drivers before connecting the radio to the computer?
If you did not then the normal Windows drivers would have auto installed and they wont work properly with the latest breed of Icom radios.
I know for a fact that we have several users that have 7610 and 7600 and the work fine with Omnirig.
Hamlib is usually a problem with Icom radios of all ages
Posted: 01 Aug 2018, 04:48
by m0vue
Nope all done before and the drivers are the correct signed ones. Icom have spent a lot of time recently re releasing drivers.
Chris
M0VUE
Posted: 01 Aug 2018, 07:38
by LA9FFA
Here is my setup:
Icom 7610 setup
Go to: Menu -> Set -> Connectors -> CI-V
CI-V Baud Rate 19200
CI-V Transceive ON
CI-V USB Unlink From Remote
CI-V USB Baud Rate 115200
- Capture.PNG (5.83 KiB) Viewed 6088 times
Posted: 01 Aug 2018, 07:54
by m0vue
Thanks I will give that a go when I get home later tonight.
Chris
M0VUE
Posted: 01 Aug 2018, 16:56
by G4DWV
Hi Chris,
One thing to try. Apparently, if there is a chain of software that work together and one is running as admin, they all have to. Got this from the Omnirig programmer himself.
The other thing to try is to set the rig in whatever program you are trying to link to as "OmniRig Rig 1" if using the Rig 1 tab in Omnirig and NOT as IC-7610. Also, make sure that the baud rates all match. You WILL have probs if they do not.
These are things that I have learnt the hard way. I have an IC-7300 and use Omnirig with JTDX and Log4OM FB.
73 de Guy G4DWV 4X1LT
Posted: 02 Aug 2018, 08:48
by m0vue
Right,
I give up!!! I design and implement software for a living and I have no idea why this is such a mess (I know I'm whinging).
I have admin rights on my laptop, I am the administrator and if I use the setting everyone else seems to be using WSJTX stops working.
Grr.
Chris
M0VUE
P.S. Just venting thanks for trying to help, I wish Radio Ham has something like ASCOM for Radio's then the manufacturer would need to get their act together as would the third parties.
Posted: 02 Aug 2018, 09:25
SpaceDawg wrote: ↑02 Aug 2018, 08:48
I understand that but have you installed ALL programs to "run as an administrator"? As detailed on page 9 of our user guide
If all else fails install Team viewer and I will try to assist
