log files gone
n8com
log files gone
Post by n8com »
hi everyone sunday i was working parks on the air and made a new data base portage lakes k-1984 i shut the program down got home opened up log4om and database gone, i can see the file in documents but it wont load into log4om when i hit open databse
Re: log files gone
What is the file extension of the file in documents?
Do you have backups set in the Options?
n8com
Re: log files gone
Post by n8com »
portage lakes k-1984 can i send you a bug report
n8com
Re: log files gone
Post by n8com »
dont see backups in options
Re: log files gone
The file will have an extension so like postage lakes k-1984.Sqlite (dot sqlite)
The bug report won't help if there are no qso's displayed
Again have you been saving backups using the Options settings?
n8com
Re: log files gone
Post by n8com »
been saving backups
Re: log files gone
Then create a new database and import the latest ADIF backup
File\new database
File\import ADIF file
K7PT
Re: log files gone
Post by K7PT »
You set up the back up path on Settings>Options>Settings 1> Right hand upper portion. If you haven't set it yourself, there is a default location where the last back up was stored.
You can select any path for your back ups in the Backup file folder box.
Click on the diskette (lower right) to save the new path.
If your logbook is empty your backup will also be empty.
Do as Terry instructed, set your back up path as noted and upon exiting Log4OM, the back up will be saved via your path.
Good luck!
