Troubles with communication with PSTRotator
oe3ide
Post by oe3ide » 26 Sep 2018, 18:58
since a couple of weeks (I don't know the exact date) I have some troubles with the communication Log4OM => PSTRotator AZ.
Setup seems to be correct and after a fresh Log4OM start, all works as expected. After a couple of minutes, a click on the heading in Log4OM, does not "reach" the PSTRotator.
Log:
Code: Select all
2018-09-26 18:50:29.8195 INFO:       Log4OMMainWindow: Sending rotator azimuth message to communicator
2018-09-26 18:50:33.2418 INFO:       Log4OMMainWindow: Sending rotator azimuth message to communicator
If I restart PSTRotator, the problem is still there. If I close the Communicator, goto Options/Services and stopp all comm-services and restart it, it works normal...for another couple of minutes. I think ~10min +/- seems to be the critical runtime.
PSTRotator AZ V 13.16
Log4OM 1.33.1.0
OS Windows 10
Both software running on the same machine
Any ideas?
73 de Ernst
Location: Höhr-Grenzhausen, Rhineland Palatinate, Germany
Re: Troubles with communication with PSTRotator
Post by DF5WW » 26 Sep 2018, 19:16
Hi Ernst,
always the same questions ... did you have installed Log4OM to run with administrator privileges ?
Maybe also PST ? Some connections need this. I can´t test so i have no rotator control running.
oe3ide
Post by oe3ide » 27 Sep 2018, 18:24
yes. Log4OM, OmniRig and PSTRotatorAZ are installed as Administrator. Also all 3 programms are started with Administrator-Privileges.
Maybe I will take a deeper look with a sniffer.
oe3ide
Post by oe3ide » 28 Sep 2018, 17:43
Ok, checked now the communication with wireshark. After a fresh start of Log4OM & PSTRotator all works good. Localhost broadcasts the Azimuth to port 12040. PSTRotator receives the udp-packet. In the Log4OM log I see the information: Log4OMMainWindow: Sending rotator azimuth message to communicator
After ~10-20 minutes there is no broadcast to 255.255.255.255:12040 .. nothing.. also no other destination ip with port 12040.
But the Log4OM log says "Log4OMMainWindow: Sending rotator azimuth message to communicator " .. but nothing happens udp wise.
If I close the communicator, stop the service via settings and restart it, it works again....
