Winkeyer TS590S Config
Posted: 14 Oct 2018, 04:59
by VE4DXR
This was working but something happened. The Winkeyer has sidetone but is not keying the rig. In LOG4OM Settings-Audio I have the Signalink USB Codec in the windows. The Winkeyer USB is connected to a Bencher iambic paddle which is connected to the rig. I have not been able to get the rig to key from Winkeyer yet the paddle does key the rig. Can anyone help? 73, Leor, VE4DXR
Re: Winkeyer TS590S Config
Posted: 14 Oct 2018, 06:52
You need to set up the Winkeyer in the Winkeyer settings not the Options/Audio.
Winkeyer does not use an audio codec it keys the radio via a com port and the radio KEY jack. Not the same com port you use for CAT control.
Radio drop down menu Winkeyer then go to the settings tab.
NOTE
Log4OM only works with the USB version of a Winkeyer, not the serial version as included in some devices like Microham interfaces
But you said it was working so you must already know all this?
Posted: 15 Oct 2018, 03:24
by VE4DXR
Thanks to your comments I realized that the cable from the Winkeyer Key1 output to the rig was inadvertently disconnected. 73. Leor, VE4DXR
Posted: 22 Oct 2018, 16:51
by w9mdb
I've just set up a WinKeyer USB and can't find any WinKeyer setup info in the settings at all.
Manual indicates there should be icon on the toolbar but don't have one.
What am I missing?
de Mike W9MDB
Posted: 22 Oct 2018, 16:58
by w9mdb
Never mind...found it under Radio/Winkeyer
Manual needs to be updated.
Mike
