Callsigns in Cluster Scanner not clickable part 2
Posted: 14 Oct 2018, 17:27
First of all I have to say Log4OM is a fantastic log program. User friendly AND powerfull.
Since I've bought my new radio (IC-7610) I have a small problem with the cluster scanner.
The callsigns present in the scanner "blink" from time to time and they are not clickable anymore. Only when I click several times, the call goes in to the callsign box and the radio will switch to the desired frequency.
(kind a looks like the problem in this topic: http://forum.log4om.com/viewtopic.php?f=6&t=3538)
Spots in the Cluster window work like they should. (double-click sets the radio to the desired frequency without hickups)
Also, I have setup FL-Digi to work with Log4OM and when I run the programs then all works fine at first but after a while, all works except the frequency is "stuck" in FL-Digi.
Maybe these issues have the same cause.....?
I'm running the newest Log4OM version, latest Omnirig version as well as the newest FL-Digi software.
Hopefully you can point me in the right direction.
Best 73 de PC9DB Mark
