Hello, I installed my LOG4MO and everything works but I can not send eQSL. My correspondents do not receive the cards. I like the program a lot and I ask you to help me!
73!
lz2cp
I can not send eQSL
Re: I can not send eQSL
You either have the wrong user name, password or nickname entered in the Log4OM/Options/External logs menu
Проверих,не е от това.Възможна ли е друга причина?
73!
lz2cp
73!
lz2cp
No way I can respond when you write in a different language - Good luck!
I apologize, I accidentally wrote in Bulgarian. My computer makes translation automatically and I was wrong.
I'm sorry!
I wanted to tell you that I checked the passwords, the username and everything is wrong. Is it possible for another to be the reason. For example, the problem is not on the site but to be on my computer!
73!
lz2cp
I'm sorry!
73!
lz2cp
Send me a support request from the Log4om help menu including an ADIF file
Hello, I found that I did not use an admin account. I guess there's a problem for that. I will reinstall it in admin and if there is a problem I will write to you.
Thanks !
73!
lz2cp
Thanks !
73!
lz2cp
There is no need to reinstall. Go to the Log4OM exe file, klick with right mousekey, klick on properties, go to the kompatibility menu item
and check the box "Run as administrator" ... After next start the software will run with administrator privileges.
Much easier than a fresh install ...
