Cluster configuration
F4IEX
Post by F4IEX »
Hi all,
I have tried to configure a custom cluster but failed :
Have already add the new cluster in the clusters' list. This cluster need an username and a password. Username is ok but cannot set the script up for the pw.
If it can helps, I've been told that the cluster is a DXspider type cluster (sounds chinese to me lol !)
Here is a copy of my script :
// use <callsign> command to send your callsign to the server.
<callsign>
//<DELAY>
//<DELAY>
ABDDE
sh/dx/30
ABCDE is supposed to be my personal pw.
Any help is welcome ! Thanks in advance.
73 de F4IEX Eric
Re: Cluster configuration
Should work, which cluster is it?
F4IEX
Post by F4IEX »
ham.crx.cloud
Is there a port number?
F4IEX
Post by F4IEX »
Port is 7300.
Here are the server details, just in case:
Bienvenue sur CRXHAM (dxNode:F4EYQ-1),
Ton compte utilisateur est actif.
Ton login web : F4IEX
L'adresse web : https://ham.crx.cloud
Version mobile : https://m.crx.cloud
La documentation est disponible ici :
https://project.crx.cloud/crx-logbook-ham-french
Le telnet se passe ici : telnet://ham.crx.cloud:7300
Ton login telnet est : F4IEX
Ton mot de passe est : ABCDE
Eric,
I cannot see why you cant log in but of course there may be an issue at the cluster server, try contacting to developer of the system as he might be able to assist you
F4IEX
Post by F4IEX »
Already done Terry, actually that is where I started at ;-)
And the dev told me to get in touch with some1 here :D
Can you confirm it is not a syntax trouble in the script ?
Syntax seems fine but you might want to try a couple of delays after the password and before the Shown DX command
F4IEX
Post by F4IEX »
It finally works !! Thanks Terry, just another delay in the script and worked !
Thanks for your help, and I take this opportunity to thank you as well for your precious videos ;)
That's good, sometimes with fast computers and internet one string will be too quickly by another and interpreted as one complete string instead of two
