Cluster beam headings for State Side stations
Posted: 24 Feb 2019, 15:55
I just noticed that beam headings for stateside contacts do not work when you are stateside yourself in the cluster. The heading is correct in the lookup at the top under extended info but in my case all stateside stations under cluster are 229 degrees. My friend Chris who lives a few miles north shows 227 for everything.
