I am running Log4OM ver 1.36.0.0 and MySQL ver 8.0
When I attempt to create a MySQL database ....... using \settings\database Fill in the information in the "yellow" block, select the 7 check boxes, this will create a database.
But when I attempt to "Check connection" I get the error "No database found"
thanks
kb3tox
unable to connect to MySQL database
Thank you for you time
KB3TOX (Ed)
KB3TOX (Ed)
Re: unable to connect to MySQL database
Did you install MySql and it's toolkit as in the user guide
Why do you need a mySql database?
*****Why do you need a mySql database?
I will be using Log4OM in a network of more than one "client" providing inputs to the database.
*****Did you install MySql and it's toolkit as in the user guide
I installed "the toolkit" ( not 100% sure what you mean). The user guide is NOT written for MySQL 8.0
This raises the question, can I use MySQL 8.0 or do I have to use the older versions 5.x???
KB3TOX (Ed)
KB3TOX (Ed)
Yes you can use later versions of MySql
I asked why because many users don't have any reason to, but you clearly do
When I get chance I will update the user guide but fully involved in V2 just now.
You need to fully instal mySql before configuring Log4om to connect to it
Terry
When I installed MySQL I selected the "server" installation. I did not believe the "developer" configuration was necessary.
I have logged into MySQL via the command prompt as "root" and it does show the "log4om" database. My gut felling is this is a MySQL permissions problem.
KB3TOX (Ed)
KB3TOX (Ed)
Did you install log4om to run as an administrator ?
Terry
Yes, it runs as admin
KB3TOX (Ed)
KB3TOX (Ed)
Try setting the MySql.exe to run as an administrator
Terry
As a test I removed ver 8.0 and installed ver 5.7.26 of MySQL ……… Full version
Had NO PROBLEM creating , testing and using the log4om database
KB3TOX (Ed)
KB3TOX (Ed)
Ok Ed I am pleased it's sorted but we need to check viability of V8 so thanks for flagging the issue
