Bearing Information in Cluster
Posted: 18 Jun 2019, 19:25
I've noticed that some of the "bearings" do not match from the "Cluster" section to the "Extended info & QSL" section. I'm curious where the cluster bearings are coming from. The examples are from my QTH in DM43ef, Queen Creek, Arizona. See examples below:
1. Bearing to HS0ZNR shows 317 within the "Extended info & QLS" tab, while the Bearing within the "Cluster" tab shows 322/142 degress. What are the differences between the two? What is causing it to display 2 differnt bearings?
Rotator moved to the bearings shown in the "Extended info & QLS" tab, 317 degrees.
2. Bearing to OY1R shows 180 within the "Extended info & QLS" tab, while the Bearing within the "Cluster" tab shows 29/209 degress. What are the differences between the two? What is causing it to display 2 differnt bearings?
Rotator moved to the bearings shown in the "Extended info & QLS" tab, 180 degrees.
