Just installed LOG4OM on the new pc in the shack.
Using G4ZLP interface and downloaded the FTDI drivers (latest 2.12.28) zip/setup.
Setup in Windows1O of the USB Serial Port (COM3) works.
Default settings.
Using OMNIRig in LOG4OM.
But whatever i try the CAT stay on RED.
Any ideas what to inspect/try?
TIA.
Ron -PA3FAT
CAT with Kenwood TS450S not working
Re: CAT with Kenwood TS450S not working
Found the issue.
Althoug default OmniRig sets baudrate to 9600 it should be 4800.
Setting both driver and Log4OM Omnigrig settings to this 4800 baud made it work.
Solved.
Solved.
