Hello Log4OM gurus. I have been searching for a daily log to coincide with my contest logging program N1MM . In my attempt to set it up I have run into a problem ?
looking at your manual and watching the you-tube videos I have got to the config set up page . My station consists of Yaesu FT5000, Microham MicrokeyerII and custom built
AMD 4 Core with 8 gb ram
I have done the new configuration thing many time but and have NOT checked the omnirig and when I go to the CAT setting drop down and pick radio FT5000
do the 4800 ect... in the COM port droop down window I only have one choice ( COM 1 ) ??????? I would like to use com 3 as that's what I use in all my other configurations through the MicrokeyerII ?
Thanks Wayne
selectable com ports
Re: selectable com ports
I went a step farther and downloaded OMNIRIG and set it up. I assume I am to put it into the Log4COM program file ? Still no rig control ?
Just install Omnirig to its default location otherwise Log4OM can't find it
Then enable Omnirig in the Log4om settings window
Now you should be able to set up your rig
