2.5 problems with connection to GridTracker
Posted: 04 May 2020, 08:44
by G7SAI
I am having problems getting log entries from WSJT-X (on another PC) either direct or via GridTracker on the same PC as Log4OM2
Any hints?
Ellis
Re: 2.5 problems with connection to GridTracker
Posted: 07 May 2020, 23:02
by DK9JC
Do you use JTalert also? JTalert and Gridtracker does not work on the same time as they both use the same ports. If you use JTalert please check the JTalert manual, very good description there. If you do no use JTalert please also check the Log4OM manual, WSJT-X is covered there.
Posted: 08 May 2020, 03:56
by DF5WW
Hi John,
don´t think that the problem ist JTalert. He wrote that it won´t work with or without Gridtracker.
Think the problem is that he is using WSJT-X on another PC. I don´t have any knowledge about
working in a network of more than 1 PC but think there´s the problem.
