Problem with Log4OM v1
Posted: 20 May 2020, 00:51
Hi all,
I am currently running Log4OM v 1.41.0.0 on a PC with Win 7 64 bit Pro.
It was working fine yesterday.
I tried to start up the program today I I get nothing. If I try to start the program again, I receive a message that it is already running. Clicking Cancel or Continue produces no result.
I can see Log4OMUI.exe is running under Processes tab in the Windows Task Manager, but nothing comes up - no screen that I can use to access the logging program.
If I end the Process and try starting the program again, the same outcome occurs. Shutting down the PC and starting from cold results in the same outcome.....
Any ideas?
Thanks,
Peter VK3PF
Any ideas?
Thanks,
Peter VK3PF
