Distance window..886 miles on most QSOS
w0xxx
Post by w0xxx »
Hi and thanks for reading....
Recently, my QSO distance for any USA based contact is automatically entered at 886 miles.
Where can I correct it?
Thanks in advance!
G4AON
Re: Distance window..886 miles on most QSOS
Post by G4AON »
Check the locator square when you enter the call sign, and whether it shows a valid QRZ.com (or QTH) lookup.
By default, you are likely to be seeing your distance and bearing from the capital... in my case it’s London with square IO91vl, for those who haven’t updated their QRZ entry.
73 Dave
G4AON wrote: 16 Jun 2020, 17:25 Check the locator square when you enter the call sign, and whether it shows a valid QRZ.com (or QTH) lookup.
73 Dave
Or if your not receiving the locator from QRZ because you don't have a PAID subscription
w0xxx
Post by w0xxx »
Ok, I renewed my subscription with QRZ, and the same symptoms exist. The map shows the same location on every domestic QSO, and logs the distance as 886 miles....it worked in the past....international map locations and distances are correct.
Information in the setting/station info is correct.
Setting section 1 info with QRZ is also correct.
I apologize but I'm running version 1. I may have posted this in the wrong section.
Moving thread to correct forums
w0xxx
Post by w0xxx »
It's working now.....I guess it takes a couple of days after subscribing to QRZ for the QSL service to start working.
w0xxx wrote: 18 Jun 2020, 20:08 It's working now.....I guess it takes a couple of days after subscribing to QRZ for the QSL service to start working.
Yep
