Hi I use Net control for logging my nets but I've not found a way of setting the frequency. I use a radio that's not CAT connected. So every time i finish a net I have to go into every entry and update the frequency.
How do I do this once and evorybody's log in the net gets the same frequency.
73 G6Jd
Frequency input and Net Controll
Re: Frequency input and Net Controll
Firstly I assume that you have selected the band and mode in the net control window and clicked the padlock to lock them as below?
That way the band and mode are saved with the QSO
Then using the QSO manager select and highlight all the qso's for the relevant net that have no frequency as in the image below.
Now go to the 'Single field update' tab and.....................................
Select 'Frequency' in the drop down marked 1
Add the value in the box marked 2
Finally click the update button marked 3
Thanks Terry,
is there a way of setting the frequency if the radio is not CAT controlled.
I set the frequency in the main screen, but that does not seem to be carried over to the log.
73 Neil
73 Neil
