Merging Logs
Merging Logs
Does Log4OM have the facility to merge several logs into one so either Awards or searching the QSO Archive looks at the complete picture as opposed to separate logs?
Re: Merging Logs
Absolutely just set up a new database and import all of the ADIF files for your variousness logbooks - It will ignore any duplicates
Re: Merging Logs
There are no "merge" facilities at Runtime (temporary)
You should create a new "merged" log where to put all your other logs with import, as Terry said
