I have 2 installations of Log4OM; one on my main desktop PC and one on my laptop. They both access the db in Dropbox. This has worked well for a long time but recently I have received the message "Not connected" after a long delay at start-up. This is on both PCs. The program works fine in that mode for normal logging, but there is no cluster information.
Yesterday I updated to latest version which installed without any problems but the same thing happens; no cluster info.
Is there an issue with the cluster or have I broken something?
Grateful for any guidance.
Chris G8AJM
No longer "connecting" to cluster
Re: No longer "connecting" to cluster
The not connected message refers to the DX Cluster connection - Try another cluster
Utilities/Cluster/Connection (F3)
This happens when a cluster in not working, we check the cluster is alive at regular intervals by sending a message to the cluster if we don't get a response we disconnect the cluster and tell you "Not connected"
Thank you Terry, I guess that means it could come back again. I'll leave it for a bit to see if that is the case, if not I'll go for another one.
73 Chris
73 Chris
Try GB7MBC its a UK cluster that is fairly reliable
Perfect!
Many thanks
Chris
Many thanks
Chris
Have had the same problem here for last couple days. I changed cluster to ve7cc.net:23 like KD2EWO mentioned in another post , all is working now. I don't know which cluster is better ? Been following W1AW past few months and the old cluster worked great for that and also DXCC chasing. Can any one recommend the best clusters to use for stateside users.G8AJM wrote:I have 2 installations of Log4OM; one on my main desktop PC and one on my laptop. They both access the db in Dropbox. This has worked well for a long time but recently I have received the message "Not connected" after a long delay at start-up. This is on both PCs. The program works fine in that mode for normal logging, but there is no cluster information.
Chris G8AJM
Thanks KD8CJ
All clusters have the same information, more or less, the important thing is how you set the cluster filters.Have had the same problem here for last couple days. I changed cluster to ve7cc.net:23 like KD2EWO mentioned in another post , all is working now. I don't know which cluster is better ? Been following W1AW past few months and the old cluster worked great for that and also DXCC chasing. Can any one recommend the best clusters to use for stateside users.
Thanks KD8CJ
VE7CC provide a small program which makes it very easy for you to set the filters called "CC User" once you have set the filters with CC User anytime that you log into VE7CC from whatever program your filters are there and working.
I have my filters set to only accept spots as follows
Only the HF bands 80 - 10 meters
All modes except FM and AM
Only DX spotted by spotters from the following countries - N.Ireland. Ireland. Scotland, Isle of Man, Wales, England, Belgium, Holland, Jersey and Guernsey
I am not interested in Christmas Island being spotted by some guy in Texas because I almost certainly would not hear the station.
Alternatively the user can send the filters to the cluster using the Cluster command directly from the Log4om cluster connection F3 window
e.g.
Accept/spots 1 by_zone 14
This filter will reject spots from spotters outside CQ Zone 14 (Eastern part of Europe)
KD8CJ could send the filter command 'accept/spots 1 by_zone 5' to just receive spots spotted by stations on the east coast of the USA
so the short answer is use a cluster of your choice but set the filters to suit your location and operating needs
Terry,
Thanks for the recommendation on CC User. Had not known of that software. Got it working, the only issue I had was I have to login with CC User, then log in with Log34OM cluster for the changes to take affect. Works well!
Thanks!
Doug
W7DRM
Thanks!
Doug
W7DRM
Terry,
I may have spoken too soon. Today, I can't seem to make cc user work. Well it works within itself, but has no affect on the Log4OM cluster display. I have cc user set to report only spots make by the US and Canadian stations. But log4OM cluster is showing all spots. Have even tried disconnecting from L4OM cluster, then connect with CC user, then re-connect with L4OM cluster. I am missing something...?
Thanks,
Doug
Thanks,
Doug
Doug,
Once you have set up the VE7CC filters using cc user then connecting to the VE7CC cluster in Log4om should provide the same cluster spots as CC user
Send command sh/mydx to VE7CC from Log4on
