ARRL Award error
w9mdb
ARRL Award error
Post by w9mdb » 25 Aug 2019, 14:25
Seeing this in the log
de Mike W9MDB
2019-08-25 14:00:43.1971 ERROR: *** ArrlAwardControl: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index ******* [Function: #=q4yCiMiTpAwSSGlpYlb5A1qseP6vGW4VSba3JiOWchilhihdWEyrvJtOAvN2XSTjV] System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
at System.Collections.ArrayList.get_Item(Int32 index)
at System.Windows.Forms.DataGridViewRowCollection.SharedRow(Int32 rowIndex)
at System.Windows.Forms.DataGridViewRowCollection.get_Item(Int32 index)
at AwardControl.ArrlAwardControl.#=q4yCiMiTpAwSSGlpYlb5A1qseP6vGW4VSba3JiOWchilhihdWEyrvJtOAvN2XSTjV(Object #=q6Me2zPo_GugSa7EE$a6zJQ==, DataGridViewCellMouseEventArgs #=qmZRDkQdSqQ6pagO8CcJawA==)
Re: ARRL Award error
Post by DF5WW » 25 Aug 2019, 14:56
Hi Mike,
which OS and which version of Log4OM ? That´s the information always needed
if anybody ask for a support. B.t.w. latest Log4OM is 1.39. If you have an older
one please download and install the new one on the fly ... but with "install as
Administrator" ....
73´s .. Juergen ... ALT-512 SDR (10W) , 50 m random wire at CG-3000 autotuner ...
Post by IW3HMH » 25 Aug 2019, 15:01
Hi, i'm checking the code. It's probably a click in the blank part of the grid, where no data are present, not correctly intercepted.
I've added another control and i'll try to reproduce it here.
Anyway it's a trivial issue, if you don't notice any malfunction on the application.
Thanks for reporting! :) i hate them, i'll try to remove all of those small things from the code (and probably i should not log some trivial errors)
w9mdb
Post by w9mdb » 25 Aug 2019, 21:43
using 1.39.0
I have been messing with the awards recently updating the LOTW DXCC stuff.
Mike
w9mdb
Post by w9mdb » 25 Aug 2019, 21:46
Also...somewhat related...don't know if you saw what appears to be a bug that I posted in another part of the forum.
The "Credit Granted" status apparently depends on LOTW being Validated and one or more credits being checked. But LOTW Validated is not done with card checks as of now.
https://forum.log4om.com/viewtopic.php? ... 300#p22300
