Log4om and winkeyer, with cw speed pot enabled.
If you send prosign CT ( _._._ ) from a key
log4om will change the winkey speed from what every it's set to,
to 9wpm.
Sending any CW prosign should not effect either Log4om or Winkey
I think there is an error in Log4OM
Log4om and winkeyer Prosign problem
Re: Log4om and winkeyer Prosign problem
This has been added to our list
Please do not double post, I have deleted the duplicate posting
Just checked out V2 and the problem still exists.
Doesn't appear to be a way to disable the speed pot in this version so no work around that I
can see
Dave G8PGO
can see
Dave G8PGO
Any idea when this may get fixed
I just re-prioritised this, apologies for the delay
Using K1EL USB winkeyer rev. 31 i'm totally unable to reproduce the issue.
The speed pot message is sent only when i move the pot on the WK.
I've tried all combinations of parameters but i can't reproduce that issue. Can you kindly tell me what WK version are you using?
