Small bug....in the QSO Info JT9 is not in alphanumeric order in the Mode select.
It shows up before JT4 instead of after JT6M
JT9 Mode select
Re: JT9 Mode select
Can confirm this. It´s wrong in the modelist.csv ... at modelist_user.txt all is in alphabetical order ..... but think it will be o.K. when Daniele fix it in the next release ?
It´s a vy small bug
It´s a vy small bug
Re: JT9 Mode select
Have fixed this for now ..... Save actual modelist.csv to another folder and insert the new one into the L4O configuration folder ....
I forgot, after inserting the new modelist.csv into the configuration folder you have to restart L4O
modelist.csv
- (2.18 KiB) Downloaded 388 times
