Reset of Awards Form
OE6CLD
Post by OE6CLD »
Hi Daniele,
When you open the Statistics and Awards form (e.g. for DXCC mixed), and sort by prefix and you next click on an entry where you have a QSL card (C - confirmed), a new windows with the confirmed contact(s) pops up (as expected).
If you close this window again (because you only wanted to check the details), the Statistics and Awards form resets back to Country order, and the focus is in the first line (Afghanistan).
All other status (G - granted, S - submitted, W - worked) are working fine, if you close the pop-up window, the focus stays on the current selection.
Is this something that can be fixed easily?
Claus, EI7JZ/OE6CLD
Claus, OE6CLD/DJ0DX/EI7JZ
Re: Reset of Awards Form
I think yes... let me check at the code...
