SOTA summit name hyperlink
HB9BRJ
Post by HB9BRJ »
Utilities > Statistics > Awards > SOTA
The "summit name" column acts as hyperlink but does not work because the SOTAmaps URL has changed recently:
URL generated by Log4OM, not working any more:
http://sotamaps.wsstvc.org/index.php
New URL required:
http://sotamaps.org/index.php
I found and successfully corrected the URL in LogOMUI.exe.config
Please update when publishing a new Log4OM version. Thank you!
Markus HB9BRJ
(Log4OM newbie, running first tests today. Very impressed by what I have seen so far!)
Re: SOTA summit name hyperlink
Well done Marcus, thanks for heads up
fixed in sources.
tnx
