Minor typos
PB4FUN
Minor typos
Post by PB4FUN »
Under Cluster (F9) there appears on the right side a tabcontrol
The caption is Highligts -> should be Highlights
Under that the caption of the Radiogroup control is "Highlight spot by" where all options are starting with "by" (being the first option starting uppercase). -> either remove the word "by" in the caption or in the caption of each radiobutton
You also use the casing of kHz different on multiple places. The official casing should be lower k, upper H, lower z (Using MHz the M is uppercase)
PB4FUN Meindert; Rig : Icom IC-9100 / Ant: Falcon OUT-250-B @4m AGL; 144 MHz 16 el @ 4m AGL; 70 cm 23 el @ 5 m AGL
Re: Minor typos
Thanks,
all fixed :)
VE3VEE
Re: Minor typos
Post by VE3VEE »
Help > LogOm Homepage (should be "Log4OM Homepage") :-)
Re: Minor typos
Oooops!
