Net Control window start time wrong
Posted: 29 Jan 2016, 09:55
When using the Net Control window, stations that are in the left hand part of the window (active in the net) can be moved up and down the list in order to keep them in the correct "running order"... However, when you move them up or down the list their start times change to the time that you move them, it should be the time they joined the net and were moved from the right window area to the left.
73 Dave
73 Dave
