Hamlib can't handle COM10 and higher
ON6NG
Post by ON6NG » 31 Aug 2016, 18:29
I have a µHam USB. I have set the port for CAT to COM14. Hamlib does not work with this port set to COM14.
I have tested this issue with rigctld in a Commandscreen.
Hamlib can handle up to COM9. Hamlib can't handle COM10 and higher.
Perhaps:
https://support.microsoft.com/en-us/kb/115831
No problem for me. I use OmniRig.
Marc
Re: Hamlib can't handle COM10 and higher
Post by G4POP » 01 Sep 2016, 08:05
This is the problem with Hamlib it is not being maintained properly and is way out of date, if I had a choice I would completely remove Hamlib from log4OM and just provide Omnirig
w9mdb
Post by w9mdb » 12 Sep 2016, 03:38
hamlib isn't being mainatined properly or is Log4OM's hamlib is out-of-date?
hamlib gets patches all the time.
If there's something needs to be changed in hamlib just need to submit a patch.
I've submitted numerous patches and new backends.
de Mike W9MDB
w9mdb
Post by w9mdb » 12 Sep 2016, 04:10
Also....have you tried using the path for the COM device as shown on your Microsoft link from rigctld?
Not sure if you need to escape the backslashes when specifying them.\
I just tested COM10 on the latest hamlib and it works fine for me on Windows 10.
de Mike W9MDB
Post by IW3HMH » 12 Sep 2016, 05:30
Simply replace the content of hamlib folder in settings folder with the last version of the Hamlib package.
w9mdb
Post by w9mdb » 12 Sep 2016, 12:51
I did confirm Log4OM could not open COM10 and tested the Log4OM version of rigctld and it also showed an error opening COM10.
I just tested latest hamlib as compiled by JTSDK for WSJT-X.
Replaced rigctld.exe with rigctld-wsjtx.exe and also had to copy libwinpthread-1.dll -- that's the only two files needed.
Log4OM then works on COM10
I'm a little confused as to how to use the serial port. I don't see a connect for that.
de Mike W9MDB
ON6NG
Post by ON6NG » 13 Sep 2016, 22:18
The Hamlib included with Log4OM dates back from 2012.
A newer Hamlib3 can be downloaded from https://sourceforge.net/projects/hamlib ... lib/3.0.1/ .
Run the installer hamlib-w32-3.0.1.exe and install (for example in C:\hamlib-w32-3.0.1\) .
The ..\bin subfolder contains the needed exe- and dll-files.
This rigctld can handle COM10 and higher.
A still more recent Hamlib3 is part of the JTSDK.
Marc
ON6NG
Post by ON6NG » 18 Sep 2016, 23:01
Info to this forum
Daily built snapshots of Hamlib3 can be found at:
http://n0nb.users.sourceforge.net/ .
I downloaded the W32 and W64 zip-achives.
The exe- and dll-files are in the bin-folder.
I deleted the original by Log4OM installed files, and copied the new files.
Both W32 and W64 versions function on my 64bit PC.
Result: Hamlib3 works for me, with COM14, to a Elecraft K3.
Daniele IW3HMH mailed me about an update in the next release.
Marc on6ng
