Report Field gets blanked out when editing a qso
VK7XX
Post by VK7XX »
I have noticed that if you edit a JT9 contact that has a plus signal strength report (eg +02) the signal report area (RST sent or RST recvd) gets blanked out. This does not happen if the report is a minus one (eg -02)
perhaps this could be fixed in the next release.
John
VK7XX
Re: Report Field gets blanked out when editing a qso
Yes John that requires attention thank you
wb9kpt
Post by wb9kpt »
John, you should be able to resolve your issue by adding +01 to +25 to the "reportlistJT.txt" file to accommodate positive signal report values.
Bill WB9KPT
It's correct.
the value is blanked because, on load, it doesn't match with allowed RST report values.
Adding the + scale on next release
VK7XX
Post by VK7XX »
wb9kpt wrote:John, you should be able to resolve your issue by adding +01 to +25 to the "reportlistJT.txt" file to accommodate positive signal report values.
Bill WB9KPT
thanks for this info Bill. I have added the lines to the file.
John
Fixed in next maintenance release that we are checking now
