PG 186 "Select 'Settings' in LOG4OM and click on the 'Services' tab and instruct the program to communicate with the other software."
There is no 'Services' tab when select 'Settings' because there is no mention of selecting "Options" after selecting the 'Settings' tab.
If I may;
"Select 'Settings' in LOG4OM and then select 'Options' and click on the 'Services' tab and instruct the program to communicate with the other software."
Regards
WB7OND
Help Manual FlDIGI Integration
Re: Help Manual FlDIGI Integration
Another mistake that has been there since I first wrote the user guide 3+++ years ago!
However I apologise for the error which is now corrected and I have uploaded the revised user guide to the server so you can download the updated version either from our website or from within Log4OM in the 'Help' drop down menu
No apology necessary, I wanted to help the next user past the point I had a slight problem... I appreciate the response and the repair, as well as the fine logging program...
