no QSO's found LOTW and eQSL
Posted: 24 Nov 2018, 18:57
by pd8gz
First of all, im very pleased with LOG4OM it's a nice and easy to use log program.
I want to thank you all for making this fantastic program.
I have although a question...i'm using LOG4OM version 1.34.0.0 and i'm trying to download LOTW and eQSL logs into LOG4OM.
When i do this some qso's give's an error message: 'QSO Not Found...'. This is very strange because they are confirmed qso's.
Sreenshot of the messages:
2018-11-24 18_08_37-Foto's.jpg (73.17 KiB) Viewed 9062 times
The settings in LOG4OM are:
I'm also using the latest version of TQSL, all the passwords and username's do not contain any 'special characters'.
Is this a known issue, and is there an solution fo this problem?
I hope you can help me.
73, PD8GZ
Gerrit
Re: no QSO's found LOTW and eQSL
Posted: 24 Nov 2018, 19:05
Have you checked the two qso's in your log to make certain that the call sign, date, time, frequency, band and mode are an EXACT match?
Posted: 24 Nov 2018, 21:31
by pd8gz
Thank you for your reply,
The QSO's seems to be oké....except time and frequency.
Here are the screenshots:
Thank you.
Gerrit
Posted: 24 Nov 2018, 21:34
Clearly if the time and frequency don't match then the download from QRZ will treat the qso's as different qso's and the result is QSO not found!
Posted: 24 Nov 2018, 21:44
by pd8gz
Oke, thank you for your fast replies.
So is it possible to change these or is not done?
Gerrit
Posted: 24 Nov 2018, 21:47
Of course! Change the information in Log4om to match and then download again from LOTW
These minor mismatches sometimes occur due to users setting up WSJT in a different manner or variances in old style loggers
Posted: 24 Nov 2018, 21:57
by pd8gz
These QSO are not yet logged in LOG4OM.
I want to download them from LOTW into LOG4OM, the other QSO's are downloadeble except these.
I assume that changes should be made in LOTW and then correctly downloadable into LOG4OM.
Thank you for your help.
73, Gerrit
Posted: 24 Nov 2018, 22:03
You misunderstand the function that you are using in Log4om, it's for updating Qso's that already exist in Log4om from an LOTW record.
It is not an import function, you need to download an ADIF file from whatever external source you use and then import it into Log4om.
Refer to our user guides and YouTube tutorials for a complete understanding of how Log4om works
