QSO Start Time ?
QSO Start Time ?
Would it be possible to include an option (in the current version or the new planned version) to enter the "QSO Start Time" automatically when you "Tab" out of the Callsign Field and enter the QSO "Finish Time" when the QSO is closed i.e entered into the database?
73 de David G4NVB
Re: QSO Start Time ?
Hi?
Actually you have spotted a bug so I will move this post to the appropriate thread.
Something has changed because it was working as you request and I had not notice the problem, I will add it as a high priority issue to Mantis
TU
TU
Hello Terry,G4POP wrote:Hi?
TU
Thank you for your reply. Sorry about omitting my name, I thought My Signature was set up, it is now!
As I'm not that active at the moment I wasn't too sure how the Log4OM Time Stamp worked so did not realise it once worked the way I would like. Look forward to using Log4om a bit more in the future and also to future developments etc.
73 de David G4NVB
I recently downloaded LOG4OM and noticed this was happening and have been using manual time selection most of the time which is a longer entry process. I didn't realise this was a bug! Looking forward to a fix coming out and looking forward to version 2 coming out too if version 1 is anything to go by!
Great software. Well done to all involved.
Davy
Davy
This issue is resolvedG4NVB wrote:Is this issue still on the "To do list" ?
Hello Terry,G4POP wrote:This issue is resolved
I've just installed Log4om (1.24.0.0) on my new Win 10 Laptop.
I typed in your callsign, it populated your name. I then "Tabbed" out of the callsign box but the start and end time are still incrementing in unison. Maybe I have a configuration issue.
73 de David G4NVB
Please wait for the next release where it is fixed - I just tested it!!!!!!!!!!!!!!!!!!G4NVB wrote:Hello Terry,G4POP wrote:This issue is resolved
No problem Terry, just wanted to make sure it wasn't me ! !G4POP wrote:Please wait for the next release where it is fixed - I just tested it!!!!!!!!!!!!!!!!!!
73 de David G4NVB
Additional Information
For "SET Start Time when leaving the CALLSIGN Field" option to work you need to 'check' the box in "Settings / Options / Settings 2 / Misc"
73 de David G4NVB
