(Remark - import error found - based on wrong handle)
I did a complete newintallation (deleted ALL SQLITE and Log4OM files before!).
I tried to import an ADIF File generated from DXlab (Log4OM tells me 25279 QSOs)
I marked "Update countries in ADIF")
- I checked with LM8 that there are 25279 QSOs inside - 18000 unique and 8000 "dupes" - dupes mean - worked twice or more on different DATEs (like contest ,....)
Import took around 10min. on a DuoCore 2*2.5Ghz with 4Gb Ram. - Ok - heavy to do -
Afterwards Log4OM show me 55000 QSOs in the database (2times more).
I exported this Log into a CSV (why do you use | as seperator?) - count was really 55xxx. Checking the "dupes" the time was once ending in :00 and the dupe was the correct one like :15
I feel, that the import function is not working as before (maybe based on the mark of "updated countries in ADIF"?). And I miss any info, that the program is working (only the Sandclock
Ok -. I found the ERROR - I pressed the SAVE button too early (I did not wait until the OK was given) - maybe you have to disable the "Disc" Save during import
I see some lines with "DXCC has changed from 126 to 15 -> others are like "from " to Finland ... interesting...
One more remark: Within the main window I can see teh DX spots - could it be possible to add a funtion that show me the spotter (if I go to the DX spot)? I am a little bit lost in this screen and I must switch to the cluster to see, who spotted this DX (Intersting to see, if I may hear the DX too)
