Award Info
OE6CLD
Award Info
Post by OE6CLD » 21 Apr 2014, 15:49
Hi all,
I started to play around with the new award feature (assigning award values to some QSOs) and found some issues. I can fix these issues locally, but these are the awards that are bundled with Log4OM:
1) If you want to attach a WFF reference to 9A (Croatia), the first entry in the list is 8RFF-001 which is wrong
2) If you try to enter a WFF reference to DP0GVN (Antarctica) the correct entries are missing. These are part of the German WFF list (DLFF-015 until DLFF-022)
3) The diacritics in most of the award texts are shown wrong, all the umlauts in a award I did myself are correct (including import)
4) A lot of entries are missing, especially in the WFF lists
More to come when I find more ;)
Anyway, thanks for this great new feature!
Claus, EI7JZ/OE6CLD
Claus, EI7JZ/OE6CLD/DJ0DX
Re: Award Info
Post by G4POP » 21 Apr 2014, 16:50
Claus
If you can supply up to date lists for these awards then we can update the awards but the ones we have used were the latest we could find!
