Version 1.18 doesn't color new countries in red color
VA3AG
Re: Version 1.18 doesn't color new countries in red color
Post by VA3AG » 06 Aug 2014, 01:38
VE3VEE wrote:Hi Aldo,
Thanks for confirming the issue on your end, too.
worked and confirmed
You might have meant "worked and unconfirmed". :-)
73 Marvin VE3VEE
You are right, sorry about that.
Aldo VA3AG
W7DRM
Post by W7DRM » 06 Aug 2014, 19:24
I can confirm the same behavior. When you select "by LOTW received" then Save Settings, close the program and reopen, your setting of "by LOTW received" is still selected, but the selected action (red highlight of those countries NOT LOTW received) does not happen. The setting is saved, but the action of the setting does not occur, until the selection is changed and reapplied.
Doug
W7DRM
Post by IW3HMH » 07 Aug 2014, 08:11
working on that.
release probably will be made soon
Post by IW3HMH » 07 Aug 2014, 08:36
Beta release will be available in some minutes to beta testers with some patches to be tested.
