DXCC Award administration - help needed
dk2lo
Post by dk2lo »
3 questions:
1. is credit granted = credit awarded (LOTW terminology) ?
2. I would like to get my DXXC Challenge standings into LOG4OM. There I have a problem:
I am successful in changing by LOTW confirmed QSOs (Validated status) into credit granted status by editing the Awards window under Update QSO.
I have many QSLs confirmed (status C) which have been accepted and awarded by DXCC desk and should also get the credit granted status. I was not successful in changing the confirmed status into credit granted. I tried several ways but nothing worked - probably user error
3. Is it possible to automate the manual process of editing the DXCC award status?
LOTW knows in Award Account Menu already all my QSLs credited for DXCC awards under Account Credits menu. This data could be used to update LOG4OM DXCC database with a bulk upload. Because I have so many credits I would need much time for the manual process and it is not error free.
I appreciate any suggestions
73 de DK2LO - Olaf
73 Olaf DK2LO
Re: DXCC Award administration - help needed
dk2lo wrote:3 questions:
73 de DK2LO - Olaf
Hi Olaf,
Firstly the ADIF terns are Credit submitted and Credit granted so we need some title changes HI!
LOTW has just now provided a credit status in the ADIF download and the next release will update your status accordingly.
Unfortunately the ARRL do not include the paper QSL credit status in this download so it is not complete - Typical ARRL! One day they will join us in this century Hi.
dk2lo
Post by dk2lo »
thank you for the superfast reply!
Great news, so the bigger part will work automatically in future, but I have still more than 900 paper QSLs which are in award granted status at ARRL. How can I do this status change within LOG4OM? For this process I still need a description because I was not successful. Any hints?
73 Olaf DK2LO
73 Olaf DK2LO
dk2lo wrote:Hi Terry,
73 Olaf DK2LO
Hi Olaf,
Yes I see this as a problem!
However when we can get the LOTW update then we can check the paper award submitted and granted status.
What program did your data come from and did that data reflect your awards status correctly? If so we can probably manipulate the imported ADIF.
dk2lo
Post by dk2lo »
before LOG4OM I used an ASCII file with selfwritten edit macros. My DXCC challenge status is maintained in RXCLUS. So no ADIF available. I will have to convince ARRL to deliver also the Papper QSL credits ... :roll:
Nevertheless a manual change of a QSO to credit granted status should be possible in LOG4OM.
73 Olaf DK2LO
73 Olaf DK2LO
73 Olaf DK2LO
Hi Olaf,
Yes manual edit is available already but you don't want to edit every QSO!
Could you generate a .csv file that shows the credits and then perhaps we could manipulate the data for you so that an import or merge could update the status?
dk2lo
Post by dk2lo »
thanks for all suggestions. What data are needed for the csv file?
Do you know an email address at ARRL which can be used to motivate the LOTW crew to implement the QSL card date for granted status for the download?
I still do not know how to change the status of an QSO with QSL card confirmed into "credit granted" status. Could you please explain the steps.
73 Olaf
73 Olaf DK2LO
K7PT
Post by K7PT »
Hi Olaf,
Go to each QSO that you have a "credit" for and select the "Award" tab in the QSO window. Then check each box for the award(s) that you have been granted for this QSO.
Chuck-K7PT 8-)
73 Olaf
Hi Olaf,
Please see the attached file for illustrated step by step instructions, I will add this to the user guide!
73 Terry
Updating Award Credit Status.pdf.zip
(460.93 KiB) Downloaded 348 times
73 Olaf
Just export all of the data in a .csv format and I can edit it in a spreadsheet to provide the correct format to convert to ADIF
