The "Y" means you have a CARD which means a QSO is confirmed and needs to be Verified by a card checker or mailed to the ARRL for Verification.
The "V" generally means a QSO has been "Matched" via LOTW and does not require any further verification.
The "V" also means that a card has been Verified by a card checker and is ready for submission to the ARRL and not yet Submitted.
Hope this clears it up for you.
LoTW Statistics Compare routine?
Re: LoTW Statistics Compare routine?
Can this file be available in a txt format? Because parse a PDF is not so funny
In an old version of the AD1C DX4WIN comparison programme, you had to go to your award matrix on LOTW - highlight the matrix - and then save as a html file. So you essentially get the same as shown in the PDF but as a html instead. All a bit clumsy, but it worked! 73 Peter
73 Peter G3ZSS
