I have noticed that if you edit a JT9 contact that has a plus signal strength report (eg +02) the signal report area (RST sent or RST recvd) gets blanked out. This does not happen if the report is a minus one (eg -02)
perhaps this could be fixed in the next release.
John
VK7XX
Report Field gets blanked out when editing a qso
Re: Report Field gets blanked out when editing a qso
Yes John that requires attention thank you
John, you should be able to resolve your issue by adding +01 to +25 to the "reportlistJT.txt" file to accommodate positive signal report values.
Bill WB9KPT
Bill WB9KPT
It's correct.
the value is blanked because, on load, it doesn't match with allowed RST report values.
Adding the + scale on next release
- VK7XX
- Old Man
wb9kpt wrote:John, you should be able to resolve your issue by adding +01 to +25 to the "reportlistJT.txt" file to accommodate positive signal report values.
Bill WB9KPT
thanks for this info Bill. I have added the lines to the file.
John
Fixed in next maintenance release that we are checking now
