Windows-XP and Windows-10 IC7300
vu2grm
Post by vu2grm »
Hi, I have been facing some issue on LOG40M : I have installed same versions 1.27.0.0 on XP and Win10. In Win10 I can see and select IC7300, on XP this is not there and with other like IC7000 etc it is not connecting. any suggestion please.
de
Ram
VU2GRM
rammohang@gmail.com
Re: Windows-XP and Windows-10 IC7300
Hi Ram,
this could not be a Log4OM problem so Log4OM is using Hamlib (integrated) and Omnirig
(external) for CAT. If you don´t see the IC-7300 on your Windows XP machine you may have
"older" version of Omnirig installed ??
By the way, we are meanwhile on Log4OM 1.28 ... Always a good idea to install the latest
version of a software ...
Corrected from 1.29 to 1.28 :D
Juergen,
The latest public release is 1.28
1.29 is currently in Alpha test and not generally available to normal users because there could be some bugs to be resolved.
G4POP wrote: 08 May 2017, 07:43 Juergen,
Only a problem with my fat fingers. Would write 1.28 but hit the 9 instead of the 8 :D :D
