Digital Mode JT9
n9jca
Digital Mode JT9
Post by n9jca »
Will there be an update for JT9 to be added to the Modes
I can find everything but JT9
Chris N9JCA EM68fb
Re: Digital Mode JT9
To implementing a new mode you can open the Configuration Folder via the HELP Button. In the folder yoi will find a ModeList.txt and a ModeList_user.txt. You can implement new modes you need with a simple texteditor.
modelist_user is created only if the user switches to ADVANCED MODE in the first screen of settings, and press the MODE button in the green area.
An editor will be open automatically, with the correct file name
Daniele
IW3RAB
Post by IW3RAB »
Hi all,
Please note that you need an recent TSQL configuration file for upload JT9 to LOTW.
Read also:
http://www.pisto.it/forum/viewtopic.php?f=5&t=188
Add only JT9 line, witout postfix (-1 -xx)
Good JT connections
Sandro, IW3RAB
Sandro IW3RAB
